Författare Ämne: Which automatic pool cleaner is better, kreepy krauly or polaris?  (läst 4049 gånger)
Utloggad briankendrick
I need to buy an auotmatic pool cleaner. I’ve heard some bad things about the polaris and I’m thinking of going with the kreepy krauly from aquabot   instead. has anyone used these? Which one will last longer and work better?
Utloggad ronson
  • Stad/land: Jämjö
  • Antal inlägg: 860
    • Ronson´s poolbygge
SV: Which automatic pool cleaner is better, kreepy krauly or polaris?
« Svar #1 skrivet: september 15, 2007, 22:54:57:57 »
Hi
I have used a similar pool cleaner, EASYKLEEN, and it was superb to use. You don´t have to connect to the watercirculation, just connect to 230VAC outlet and it will transform a 12V voltage to the cleaner.
Drop it down it the pool, it scan of the pool bottom automaticly. It stops when it is finished. After that you have a clean pool. The dirt is collected inside the cleaner. Takes appr 2.5h to run the program, just relax and take a beer or two meanwhile.
It also crawl up appr. 0.5m on the wall side. I have a pool with sandwall and it crawls up also above it.
Work to at least 10X4m poolsize.
You can find it here:http://www.svenskpoolservice.se/
/ronson
