Vet du vilket controller som sittar i din värmepump? Har just kopplat min G&J till Home Assistant via MODBUS. Kör kanon bra, med mycket bättre prestanda än den otroligt dåliga app.Min controller är en PC1002, men tror också att PC1004 går.
Delar du möjligtvis med dig din kod för HA?//Daniel
modbus: name: "modbustcp" type: rtuovertcp host: 192.168.x.x port: 4002 delay: 2 timeout: 2 climates: - name: "Heat Pump Setpoint" address: 1016 slave: 1 count: 1 input_type: holding data_type: int max_temp: 35 min_temp: 20 offset: 0 precision: 1 scale: 0.1 target_temp_register: 1013 temp_step: 1 temperature_unit: C switches: - name: Heat Pump On / Off address: 1011 slave: 1 write_type: holding scan_interval: 20 command_on: 1 command_off: 0 verify: sensors: - name: Heat Pump Compressor Current slave: 1 address: 2054 scale: 0.1 precision: 1 scan_interval: 36 unit_of_measurement: bar - name: Heat Pump Electronic Expansion Valve Output slave: 1 address: 2020 scan_interval: 36 unit_of_measurement: N - name: Heat Pump Output Frequency of the Compressor slave: 1 address: 2021 scan_interval: 36 unit_of_measurement: Hz - name: Heat Pump Compressor Current slave: 1 address: 2051 scale: 0.1 precision: 1 scan_interval: 36 unit_of_measurement: A - name: Fan Speed slave: 1 address: 2061 scan_interval: 34 unit_of_measurement: RPM - name: Heat Pump Suction Temperature unit_of_measurement: °C slave: 1 address: 2045 scale: 0.1 precision: 1 scan_interval: 28 - name: Heat Pump Inlet Temperature unit_of_measurement: °C slave: 1 address: 2046 scale: 0.1 precision: 1 scan_interval: 30 - name: Heat Pump Outlet Temperature unit_of_measurement: °C slave: 1 address: 2047 scale: 0.1 precision: 1 scan_interval: 32 - name: Heat Pump Coil Temperature unit_of_measurement: °C slave: 1 address: 2048 scale: 0.1 precision: 1 scan_interval: 34 - name: Heat Pump Ambient Temperature unit_of_measurement: °C slave: 1 address: 2049 scale: 0.1 precision: 1 scan_interval: 38
Tack för inspirationen (och för koden), snacka om att öka användarupplevelsen med 200% jämfört med appen.Q20 pump med PC1002, uppkopplad med en EW11.Till er som vill använda en EW, inställningarna på serieporten: 9600,8,1,NONE, halv duplex, protocol: none.Fungerar över förväntan.
